spread project beetween few constructors
Hi everyone,
I heard there is a command in NX, which allow spread  project between few constructors. Do you have any idea where I can find this command ?? Or maybe do you know some similar operations??
best rgards
lukipap
Re: spread project beetween few constructors
I am not sure what you are asking for, but if it is for the ability of a group of people to work on a single complex part the the answer is, yes it can be done and it is done with part modules. Here is an image of what  it means.
PartModule.pngPart Modules
Scott
Refer the documentation for more information
Part Modules
Ganesh
