switch to fully constraint color ... auto.. is it possible ?
plain and simple question, I am trying to get my sketches to turn to the fully constraint color automatically... can not find how to do it or if it is even possible. thanks
Re: switch to fully constraint color ... auto.. is it possible ?
I do not know what version of NX you are running, but out of the box the fully constrained and partially constraint colors only display after you have changed some of the defaults.
If you disable continuous auto dimensioning and delete some of the auto-dimensions then your sketch can be partially constrained. With auto-dimensioning enabled (default) the sketch is always fully constrained.
Regards, **bleep**
You can find the required color settings under customer defaults by the following path: Customer Defaults -> Sketch -> General -> Part Settings
Ganesh
