synchronous modeling
hi gud eve to all....
                            now i am facing one more problem i had work with .step file i can't delete the radius face  anyone can help me how to delete the radius in .step file using synchronous modeling.ug 1.pngug.png
17 REPLIES 17
Re: synchronous modeling
Hard to get the real picture without the part file but i assume you are not selecting all the Blend faces (i assume it is a blend on U shaped edge?) so select all the blends in continuation.
Best Regards
Kapil
i had try but again get the same error..give me your mail id i will send that file
You can send me a private message and attach the file if you wish to...
Best Regards
Kapil Sharma
in private message no optios for file attachment....
Ok ....if you need a secure sharing then GTAC will be the best option to try...if you can share it here itself then you can also share it here itself.
Best Regards
Kapil
Please find the movie attached below. Does it work for you also? The key is to use OPTIMIZE face first (since it is an imported data) and then use delete face.
Best Regards
Kapil
Thank you so much sir....i never forget you thans a lot sir
