toggle switch for ref curves/points in sketch?
Is there any toggle swtich in sketcher, that would make all the to-be-created curves or points to be reference objects by default?
Thanks!
Re: toggle switch for ref curves/points in sketch?
So far i know there is no quick button/setting to auto create reference curves when creating lines in a sketch.
What you can do is after you created the curves use the feature "Convert To/From Reference"
In this feature you are able to select multiple curves and convert time in 1 time to reference curves.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi @ruud_vandenbrand   Thanks for your reply!
Very often a sketch is mainly composed of reference objects. It seems to be a little painful to convert manually.
"Very often a sketch is mainly composed of reference objects."
Not true for everyone; in fact, you may be in the minority on this point.
Hi @cowski1   You are right! Let me correct it: "Very often for myself, a sketch is mainly composed of reference objects."
@surfactant,
When finished with your sketch curves, set your preselection filter to curves, Ctrl+A to select all curves, MB3 -> Convert To/From Reference. That's about as efficient as I can think to accomplish what you're wanting but someone else may have a better method.
-Tim
Hi @TimF   Thanks!  Often in my sketches, there may be 5 general curves/points and 20 reference curves/points. With Ctrl-A I would still need to deselect those curves/points not for conversion to reference.
@surfactant,
Probably a good idea for an ER - have a Reference Curve toggle in Sketcher, either added to curve dialogs or just a standalone icon that did this for all curves - they've had similar ON/OFF standalone icons in the past....like the Associativity icon in Lines & Arcs toolset.
-Tim
Hi @TimF  Yes. A standalone toggle switch would be great!
@surfactant,
Call it into GTAC and you're on your way!
-Tim
