ug convert NX 11
Has the UGconvert.exe moved, I can't seem to find it in UGII in NX11
Brian
NX 11.0.2
Win 7 pro 64 bit
quadro k4000
Re: ug convert NX 11
You'll find it in %UGII_BASE_DIR%\NXBIN
Central runtime directory concept
Starting in NX 11, to help you find executables and libraries, and distinguish them from configuration files more easily, a central runtime directory that contains DLLs, executables, and JAR files is used. The central runtime directory will be updated as NX supports more and different applications.
https://docs.plm.automation.siemens.com/tdoc/nx/11/release_notes/#uid:xid1104930
Regards, Ben
perfect, thankyou
Brian
NX 11.0.2
Win 7 pro 64 bit
quadro k4000
