update with promote body
Hello, Is there a way to prevent updating of all the downstream components when doing modification of a component that is part of an assemblies that uses promote bodies? everytime I do a modification on an operation, NX10 updates ALL the features of the upper level part (that contaning the promoted bodies) this eats up a lot of time.
Thank you for your reply
Eric Ferland
NX12 user
Re: update with promote body
You can set in menu->tools->update->interpart update a delay on geometry
This will stop the auto update when there are linked bodies.
if you set the delay you can update manually when you want to update the geometry.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Great, thanks!!!
Eric Ferland
NX12 user
