view NX10.0
Dear all
I am using NX10.0.2.6 MP1 . I have some problem about view. I want to use view follow WCS .
When I rotate WCS  view ( attach file picture )  is follow WCS . Please advice to me .
thank you
Re: view NX10.0
I'm not sure what it is that you're asking.  Could you repeat the question and provide more information about exactly what it is that you're attempting to do?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Re: view NX10.0
Those views are always based around the Absolute Coordinate System and cannot be changed. If you want to create views based on your own CSYS, then I would recommend using a View Set to create them quickly. https://vimeo.com/100668876 is a video we created that shows how that works.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
