Access to Limits and Fits Style Tolerance Settings in NX 11.0.1
Dimension on-screen dialogs in NX 11.0.1 now include the deviation and grade options for Limits and Fits style tolerances.
When creating or editing Rapid, Linear, and Radial Dimensions in Drafting and PMI with Limits and Fits style tolerances, you now have the option to specify the tolerance right within the on-screen dialog.
 This makes it easier to work with drafting and PMI.
Contributors
