Design: Channel Ratio Check
Community Manager
The latest release of NX brings us a channel ratio check feature. You can find and check internal channels that may be too long and thin to evacuate powder. This allows for early corrective action to fix design issues based on the 3D printing approach prior to sending models downstream for manufacture.
What's new?
  • Table to set orientation angles and minimum diameters
  • Segment length to check to localize the area of checking
#IngenuityisNX
