Fine Tune Sequence of Operations for Kinematic Studies Using Animation Designer
If you make products that have moving parts, chances are you want to see them in action and need to know kinematic properties such as displacements, velocities, accelerations, and even collisions. New in NX 12 is Animation Designer and it will do just that. This video shows how to define a realistic sequence of operations using motors and a video-editor like timeline control. Learn how to:
• Add position motors to joints
• Use a time line tool to adjust sequence of operations
• Mirroring and splitting events
• Using an automatic update option to see sequence changes in real time
This video will help you get started with creating kinematic studies using Animation Designer. For details or a demonstration, ask your sales partner for NX Animation Designer, Product ID NX30178.
(view in My Videos)
Kris Kasprzak
