How to Add Tooltips to Dialog Box Favorites in NX 11
From NX 11 you can save a favorite version of a command dialog box with a description. The description text appears as a tooltip when you point to the favorite version’s name on the dialog options show_menu.gif menu
sfd nx 11.pngNX 11: Save Favorite As dialog with Description
sfd tooltip nx 11.pngNX 11: Saved favorite with tooltip information
 Prior to NX 11, command favorites can be saved with 'Name' only.
sfd nx10.pngNX 10: Save Favorite As dialog
With this new feature, you can reuse the saved favorite data with description effectively that helps to identify the data with tooltip information.
Ganesh
Contributors
