How to Perform Detailed Threads in NX 9
thread.jpgIn this tutorial, you'll learn how to use detailed thread using THREAD command.
Question: Why should I DETAILED THREAD insted of HOLE command?
  • Basically, when we use HOLE command to apply thread on any hole, this will apply only thread symbol but not a perfect thread.
  • HOLE command has another limitation: You can't apply external thread.
  • Whenever it's time to report or present, I would suggest to use Detailed Thread for applying thread.
Detailed Thread can show and edit its various properties such as:
  • Minor diameter
  • Pitch
  • Length
  • Thread Angle
  • Thread Directions
The short keys I used during the lecture:
To view nearly orthographic view: F8
Have any questions? Comment below.
Rinkesh Patel
Mechanical Design Engineer
www.rinkeshpatel.com
Summer Regards,
Rinkesh Patel
Contributors
