Increase Data Reuse with Geolus Shape Search
See how to increase your part reuse by using Geolus Shape Search to quickly find existing data.
Oftentimes, companies have huge libraries of parts, many with duplicate parts due to designers' inability to find what they need quickly and easily, which leads to recreating the same or nearly identical parts over again. This is especially true in the case of screws, washers, etc.
Geolus Shape Search saves designers time and companies money by presenting a solution in the form of a quick, easy way to locate existing designs and data.
(view in My Videos)
Comments
Hi Scott,
Do you have available documentation for the installation or usability of the geolus search?
This is the best place to start.
Geolus Docs
Scott
Contributors
