Joining: Easy Spot Enhancements
Community Manager
 All new in NX 12.0.2 features enhancements to joining. Improved interaction with Easy Spot makes creating a variety of discrete welds at once fast and easy. This is possible by utilizing rules based placement methods for selected components.
New enhancements feature:
  • Provide the ability to change the side of the stack up that the discrete joint will be placed
  • Allow changing the ‘type’ of discrete joint being specified from the results dialog
  • Flip the normal direction of the weld CSYS
  • Change the Y axis of the weld CSYS
  • Center on overlap sheet being worked on
  • Added User Exit that gets invoked after Easy Spot completion
NX Help Documentation - Easy Spot enhancements
#IngenuityisNX
