Joining: Impact Analysis Improvements
Community Manager
 All new to NX 12.0.2 features enhancements to joining. Impact analysis now provides a specific check to verify whether all of the joints parent parts are still in the loaded assembly. The improvements will help identify changes that have been made to an assembly since the welds were generated saving you time from having to manually search.
The improvements to impact analysis include:
  • Enhanced the Impact Analysis check by adding a Missing Part check that indicates when a Connected Part associated with a weld is no longer in the assembly.
  • Works with all weld types: discrete, arc, sealer
  • Works on both legacy and Individual discrete joints
  • Can be solely executed with Checking level pulldown
#IngenuityisNX
Contributors
