Joining: Rules Based Structure Welding
Community Manager
New to Joining in the latest release of NX features Rules Based Structure Welding. Rules Based Structure Welding provides additional user control of the weld data that gets captured and passed along. This ensures proper results for downstream usage of the weld information, improving efficiency.
What's new?
A welding joint establishes a connection between the parent part components that it is joining and passes it along to the Teamcenter object where it gets used by downstream application.
  • This enables the user to specify what value should be captured and reported as the ‘Connected To’ when a weld is joining parts from a promoted assembly (assembly cut or deformed).
NX Help Documentation - Weld Joint enhancements
#IngenuityisNX
