Expressions in NX are arithmetic or conditional fomulas that let you control relationships between features in a part or parts in an assembly. For example, you can express the thickness of a bracket in terms of its length. If the bracket length changes, the thickness automatically updates to reflect that change.
You can use expressions to define and control many dimensions of a model, such as dimensions of a feature or a sketch.
In this NX Quick Tips video, I'll show you how I use Attributes and List Expressions to change a part.
Formulas within expressions can include a combination of variables, functions, numbers, operators, and symbols. You can insert expression names in the formula strings of other expressions.
This post originated in the NX Design Blog. You can view original comments on this post here.
