NX Quick Tips – NX 9 Blend Pocket
Many industries require milling of complex blended pockets. Regular blending methods may not result in a pocket that is modeled as it will be machined.
You can avoid downstream manufacturing problems when you analyze and validate pockets to blend prior to modeling them. There are other benefits to using pocket blends too:
  • Improve quality
  • Increase efficiency
  • Improve weight estimates based on the model
In this NX Quick Tips video, I’ll show you how to use the new Blend Pocket feature in NX 9.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
This post originated in the NX Design Blog. You can view original comments on this post here.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
