Do you mean
NX Quick Tips - NX 9 Hole Callout
by Siemens Phenom Siemens Phenom ‎02-05-2015 12:14 PM - edited ‎02-09-2015 10:56 AM (1,960 Views)
Now you can create associative callsouts for holes and threads based on the hole's feature data with the new Hole Callout option in NX 9 linear and radial dimensioning.
You can apply hole callouts to many things:
  • Symbollic threads
  • General holes
  • Drill size holes
  • Screw clearance holes
  • Threaded holes
The Hole Table command creates ordinate style hole locations arranged in a table. The table can contain individual columns for labels, category IDs, hole types, diameters and depth. The table can cover all general hole types, including drill size holes, screw clearance holes, and threaded holes.
This post originated in the NX Design Blog. You can view original comments on this post here.
Contributors
