Do you mean
NX Quick Tips – NX CAE Stress Wizard
by Siemens Phenom Siemens Phenom on ‎04-30-2015 10:32 AM (1,215 Views)
NX CAE Stress wizard gives you a first look analysis to see if your product will perform as expected. No CAE experience is necessary to get started; it’s straightforward and simple.
The wizard guides you through the process with step-by-step instructions, so you can get some quick feedback on your designs. It even “thinks” for you, to determine variables such as finite element size based on your model.
You don’t have to be a CAE expert to get the results you need. Make informed product decisions, and expedite your process! The wizard is an OOTB (out of the box) feature, so anyone with NX should have access to it.
I’ll show you how easy it is to use the NX CAE Stress Wizard in this NX Quick Tip.
Contributors
