NX Quick Tips - Part Module
Siemens Genius Siemens Genius
Siemens Genius
Part module in NX lets you divide work among your colleagues for better collaboration. This functionality allows multiple design engineers to work on the same part at the same time. You can get things done so much faster with this method.
Starting in NX 10, you can now drag and drop parts into the part module.  In the past, if you forgot to build a part in the module, you would be out of luck. Now, you can add partson-the-fly as you need.
In this NX Quick Tips video, I show you how to use the part module with the example of an automotive dashboard.
(view in My Videos)
Sam Kuan
Contributors
