NX User Experience: Improved Units Handling
Community Manager
New to the latest release of NX for your usability features changes to the units handling. This ensures that internal angle calculations are done correctly without the need for conversion factors in some expression formulas
What's new?
  • Change the base unit for angles from degrees to radians
  • Change base unit of all measures with angular dimensions to be consistent with the ANGLE measure
  • Change the conversion factors of all derived units of measures with angular dimensions to convert correctly to new base units
NX Help Documentation - Enhancements to angular units in expressions
#IngenuityisNX
