NX uses business logic of Teamcenter BMIDE Item Types to perform an assigned Save action
Siemens Theorist Siemens Theorist
Siemens Theorist
In NX 11.0.1, NX uses business logic ofTeamcenter BMIDE Item Types to perform an automated Save Action
  • A non-modifiable component (e.g. Released, CO Intelligent Save.JPGto another user), if changed in the NX session, may have a TC action defined so that the component is:
  • Saved (new version)
  • Revised (new revision)
  • Save As (new part)
  • Ignored (take no save action)
  • Business logic determines if, and how, a user may change the default assigned Save action to a different Save action prior to executing the Save
Customer Value
  • The user is guided by business practices through the Save process.
  • Multiple parts are handled in a single dialog and UI
(view in My Videos)
Contributors
