Revise on the Fly in NX 11.0.1
Released data can be revised on the fly.  This means that you can start modifying the released data and during Save, you can define if you want to create a new revision (Revise), create a new item (Save As), or ignore the change (Ignore).
This is demonstrated in the following video.
(view in My Videos)
Contributors
