Self-intersecting Surface Alerts in NX 11.0.1
When performing a series of surface commands in NX 11.0.1, you will be warned if the output faces intersect themselves.
An alert will appear in that case:
You can ignore the warning and proceed. In that case, the feature will be marked up in part navigator with a warning:
This applies only to self-intersecting faces, not two different faces of the same feature that intersect.
Enhanced Commands
The self-intersection alert has been implemented for following surface commands:
  • Law Extension
  • Section Surface
  • Studio Surface
  • Through Curve Mesh
  • Through Curves
  • Ruled
  • Bridge
  • Swept
  • Styled Sweep
  • Variational Sweep
  • Sweep Along Guide
  • Tube
  • Silhouette Flange
  • Styled Blend
Contributors
