Settings Dialog Titles in NX 11.0.1
All drafting and PMI settings dialogs prior to NX 11.0.1 are titled “Settings.” Some users find it difficult to understand the difference between each Settings dialog. To assist users in having a better understanding of accessing NX settings, beginning in NX 11.0.1 the title on Settings dialogs launched from another command will reflect the parent dialog that it is launched from.
For Settings dialogs opened from a command dialog, the dialog title will be “Command Name + Settings.”
For Settings dialogs opened from a Scene dialog, the dialog title will be “Tooltip Name + “Settings.”
