Tooling: Cooling Design Improvements
Community Manager
Improved with additional functionality in the latest release of NX, cooling design enhancements allow for a greater flexibility of design.
What's new?
  • Set of channel diameters can be defined as default for users to access during the design process
  • Channel diameter list available in Pattern Channel & Direct Channel
  • New option to control the distance of the cooling channel end to boundary of the selected part
  • Distance to the boundary can update when the end point of the channel changes
NX Help Documentation - Control cooling channel depth with a boundaryControl of cooling channel diameter
#IngenuityisNX
