Tooling: Easyfill Analysis
Community Manager
New to NX for tooling features the Easyfill Analysis. The cooling and warpage capabilities helps perform validation of the part early in the product development stage all within the same CAD environment.
What's new?
  • Full analysis capabilities (Flow, Packing, Cooling and Warpage)
  • New surface meshing methods – generate mesh with customized mesh size
  • Added gate wizard as part of the select gate function
  • Generate reports of full analysis – including cooling and warpage
#IngenuityisNX
