Variational Sweep - Practical Use and Enhancements in NX 11.0.1
Variational Sweep in NX is a tool that has improved over time and is, to date, a very powerful tool in many situations - including those areas which have been overlooked where traditional modeling techniques are utilized.
variational sweep NX 11.jpgThe following demonstrates a small sample of the powerful functionality contained in Variational Sweep:
  • Multiple Section Strings as well as Individual Section Strings in a multiple cross section string defined sketch
  • Intersecting Section Strings
  • Multiple resulting entities (Sheet Bodies & Solid Bodies)
The command supports a wide range of workflows while designing various complex system of parts where the sectional interpart relationship needs to be specifically controlled and maintained, such as a vehicle door to bodyside system of parts.
Have a look at the video below to follow the process steps of the multi-step workflow of sculpting a multiple interpart rocker area.
(view in My Videos)
