Weld Assistant - Minimum Distance Spacing option
 In Weld Assistant there a number of powerful creation techniques for locating discrete joints including spacing points along a guide curve. This new spacing option provides an easy to use spacing method that delivers desired results quickly eliminating manual calculation and guess work.
This option:
  • Calculates and then evenly spaces the points between start and end point using the minimum specified input to compute the optimal value
  • Provides real time feedback of the value determined by the calculation
  • Works with any discrete joint type: spot weld, joint mark, mechanical clinch, custom weld
