Weld Assistant – New Marker Symbols
Support for additional marker types allows more configuration choices and allows more distinction between discrete joint types. The Weld Assistant allows each customer the ability to configure the symbols that will be used to designate a specific joint type. For example a spot weld joining 2 components may have a different symbol then one that connects 3 or 4. With this release the choice of available markers has now been expanded.
  • Added 30 additional Markers that can be assigned to discrete joint types
  • Markers appear as a representation of the assigned joint type
  • Supports multiple panel symbol progression strategy
  • Very high quality renderings
