ANT Column "Weight Status" ; is it customizable
We need to know when users are Asserting values in Weight management and removing the assertion.
I could not find any NX open reference to determine if this value is set or removed. Is there any way to know the "Weight Status" column value in ANT. Any help is is appreciable.
Re: ANT Column "Weight Status" ; is it customizable
The UFWeight .AskProps method can tell you the value and wheter it is asserted or not.
Thanks, it's a reminder for me to always check the wrapper functions too..
