API for EXTRACT curve
Trying to create simple automation for extracting the edge curves everything visible in the Work view.
Searching for the NX ope API for "Extract Curves-All in work view" for the VB journal.
Below is the snapshot of the command in NX 10.
Menu=> Insert => Derived curve => Extract => All in Workview.
Please help!
Re: API for EXTRACT curve
The  "Extract Curves-All in work view" creates view dependent curves visible in the current work view.  Therefore a program would need to
1. Get the current workview
2. Get all the edges of the bodies of interest
3. Extract the edges
4. Convert the extracted curves from model to view dependent
Frank Swinkels
