About the layer properties and categories
      I want to export some single parts in the high version to open in the  low version. Is there a good way to save the layer properties and categories?(I use export--parasolid,But failed, what is the reason?)
Re: About the layer properties and categories
I don't think any of the translators support layer category info.  Not sure what you mean by layer "property" (are you saying just what layer an object is on?)
What is failing - the entire export/import, or just the layer info?
If the entire export/import, note you need to select the parasolid version to export to (so the parasolid data is compatible with the earlier NX version)
If I use export-Parasolid ,How to inherit the layer information before converting the file?
