Accessing the "Identify Results" (GUI/Tool) for a program?
To all
Does anyone know the "keyword(s)" to access the tool 'Identify Results', see attached? Tried recording a test case but there's nothing in the journal, except the group creation.
Re: Accessing the "Identify Results" (GUI/Tool) for a program?
Unfortunately, Identify Results is a command whose basic structure is untouched from the UG Scenario (pre NX) days. As such, it is not journal enabled and has no user API access.
You'll need to build your own tool using ResultAccess to get at the results data. Depending on what you are ultimately trying to accomplish, some of the other, newer Result Manupulation tools (Probe, Combination, Reduction, etc.) that are journaled may be able to help with part of the job.
Thanks JimB. Suspected something like that
What i am trying/thinking of doing
From a SOL103 Resp. Sim result = stress
For Each Normal Mode find the N highest stress  (at nodes)
 create a group containg these N nodes (and attached element)
Next Mode
Union all the groups created in previous loop into 1 groups
Just had a quick look a the option under "Combination" tool and it seems that the only option is for max or min value. I am really hoping to be able to get the top N max (where is a user defined number) (i.e say the top 10 values). Looks like it might be a dead end
I believe the "Identify Results" can be used in a NX macro
Hello selex_ct
Perhaps my post can give you a head start:
Probe across multiple solutions
Frederik
just seen your other post and had a quick look at the file 'ProbeReporting.vb'. Would need a bit of time to work my way through.
Have you got a work flow of the programe you created by any chance? Might be easier to start with
