Activate HD3D Checkmate on NX Startup
Builder
Builder
All,
     Is it possible to Activate HD3D Checkmate Navigator by default when NX startup.
Using dpv, NXOpen, KF, macro options.
-Pradeep
NX9 - TC10
PradeepECR
NX7.5 TC8/ NX9.0.2.5 TC10.2
Re: Activate HD3D Checkmate on NX Startup
Builder
Builder
I tried to open CheckMate HD3D window thru NXOpen Tool execute to show CheckMate object Tag. using Validation/ValidationOption/Parser classes, not successful to activate HD3D window yet. Anyone have tried it in NX9/NX10 ?
PradeepECR
Did you finally find a solution?
Thanks.
in NX 10 there is ResourceBarManager C++ class, which may help to activate "HD3D Tools" tab of the resource bar. However, it will not get into "Check-Mate" section inside the tab.
When I run a Check-Mate profile programmatically, I present the resulting xml report in the internal NX web browser (in order to display xml files, set UGII_WEB_BROWSER_FACTORY=iewebbrowser)
Hi
Ok great.
I'm using the ResourceBarManager as well but still got the same issue (for another tab): can't access or modify the HD3D panel itself. Not a big deal, I've found another solution.
Thanks for your reply.
