Do you mean
Reply
Solved! Go to solution
Add a second browser in resource bar
Hello
Is there any possibility to add a second Browser in the resource bar? There is a standard Browser. But i would like to add a second custom Hompage.
Is there any solution?
Tank you :-)
Solution
Solution
Accepted by topic author Bernhard_Swiss
‎12-13-2016 07:24 AM
Re: Add a second browser in resource bar
[ Edited ]
If you set the UGII_IDEAS_NX_TRANSITION_DOC variable to a http address (example below) UGII_IDEAS_NX_TRANSITION_DOC="https://community.plm.automation.siemens.com/t5/NX-Programming-Customization/Add-a-second-browser-in..."
It will create a new, second browser in the resource bar. It's designed for NX-Ideas transition docs, but it's the only way I know of adding a second browser.
Anthony Galante - Senior Support Engineer - PhoenxPLM (Australia & New Zealand Siemens Solutions Partner)
http://www.phoenxplm.com.au/email/2014_signature/signature_videoCenter.jpg
Thank you very much
This is exactly what i need Smiley Happy
