Ask face tag from Point on Face
Is it possible to get the face tag from block styler of  "Specify Point" -> Point on face?
I just want to simplify the process so user no need to select the face again.
Terry
Re: Ask face tag from Point on Face
You can get the point coordinates and then if you have a collection of faces you can ask face properties for the selected point.  If the distance is less than the distance tolerance you have found the correct face.
Frank Swinkels
