AskTypeAndSubtype for Dimensions
hi all
i'm using
ufs.Obj.AskTypeAndSubtype(object1, type1, subtype1)
i want to ask for the type of dimension and do something with particular type with
select case subtype1
where i can find list of values representing type of dimension with AskTypeAndSubtype?
BTW
NXOpen.Annotations.DimensionType. has not the same value as i get using AskTypeAndSubtype
Thanx in advance
dj
Re: AskTypeAndSubtype for Dimensions
In the .NET programmers reference there is the hint that this is a wrapper function.
There is also a link to the description of the original C function, there you will find the hint that the values can be found in the file uf_object_types.h
The complete path to this file is "%UGII_BASE_DIR%\UGOPEN\uf_object_types.h"
Not all object types can be found there, since some are declared in a different C header file ending in _types.h
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
hi -
Take a look in this "folder" in  *net_ref.chm.
NXOpen.UF Namespace
Here you can find all the good stuff.
