Asking About License
Hi All , is there any one know about this piece of license file below
INCREMENT nx_freeform_2 ugslmd 31.0 permanent 7 SUPERSEDE \
what "permanent" meant here ?
thanks in Advance
Re: Asking About License
Permanent means that this is a license that is not limited for a specified time period. There are also annual licenses, which you have to renew each year, for example.
thank you stefan ,,, btw i have task to create custom license usage ,,, and there are package f1,mrp but the rule i created couldnt limit the package usage, its failed, i dont know why ,,, have you experience like that ? or maybe you have document for custom license usage (opt file)
See the manuals here:
https://support.industrysoftware.automation.siemens.com/docs/common_license/
I think the "license administrator's guide" is what you want
Look for the section on the "options" file
thank you ken ,,,
btw i wanna create some policy for license usage by client, i wanna restrict for HOST_GROUP hsisjakarta3 only for 2 gateway usage, but why the third pc on that HOST_GROUP still can open NX
here the config is,
GROUPCASEINSENSITIVE ON
HOST_GROUP hsisjakarta3 IC1207002 siemensdc SIEMENS-HP1 HPZ420-2
GROUP Adm1 Administrator
INCLUDE gateway HOST_GROUP hsisjakarta3
MAX 2 gateway HOST_GROUP hsisjakarta3
here the log is
10:30:04 (ugslmd) TCP_NODELAY NOT enabled
10:30:06 (ugslmd) OUT: "gateway" tcosuser@HPZ420-2
10:35:49 (ugslmd) DENIED: "gateway" Administrator@siemensdc (Licensed number of users already reached. (-4,342))
10:35:49 (ugslmd) OUT: "gateway" Administrator@siemensdc
10:39:18 (ugslmd) OUT: "gateway" Administrator@IC1207002
If there are four PCs in the group all four can open the license as long as there are a maximum of two available at the time of check out.
When you do have bundles, the bundle prefix must be used too, since the license name includes the bundle prefix.
License names must match exactly as listed in the increment section of the license file.
