Assembly Sequence _NX 9
I have the following requirement. create a sweep envelop of the assembly items based on movement. (Example a rack and pinon is there I want to have maximum and minimum limits as a body or facet).  In NX9 I believe there is no direct NX open methods for sequencing, I have to go with UF only.
1. Create sequence.
2. Start sequence motion based on CSYS to CSYS component move or each arrangement as a motion from default position.
3. Measure the sweep volume for all the motions to find the complete volume of all mechanism.
This below code I created for assembly arrangement creation using sketch, expression, CSYS, Table and component groups (Kinematics taking too long for each time update it saves me like 95% of time than kinematics). I just want create the sequence using this method to move component as I already have this setup in all my assemblies. Just want to know the UF commends to create the motion and the volume. I have found only this in API document.
ufs.Assem.InitializeSequencing()
        Dim SeqName As String = "Motion Envelope Sequence"
        Dim Mysequence As NXOpen.Tag = Nothing
        ufs.Assem.CreateSequence(SeqName, workPart.Tag, Mysequence)
        ufs.Assem.ActivateSequence(Mysequence)
Arrangement code:
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.Collections
Imports System.Runtime.InteropServices
Imports NXOpen
Imports NXOpen.GeometricUtilities
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports NXOpenUI
Imports System.Collections.Generic
Module ArrangementUpdateNew
    Dim workPart As Part = theSession.Parts.Work
    Dim displayPart As Part = theSession.Parts.Display
    Dim theUI As UI = UI.GetUI
    Dim ufs As UFSession = UFSession.GetUFSession
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        lw.Open()
        Dim i As Integer = Nothing
        Dim j As Integer = Nothing
        Dim k As Integer = Nothing
        Dim ii As Integer = Nothing
        Dim ij As Integer = Nothing
        Dim ik As Integer = Nothing
        Dim PrimeCsysList As List(Of CoordinateSystem) = New List(Of CoordinateSystem)
        Dim SecondaryCsysList As List(Of CoordinateSystem) = New List(Of CoordinateSystem)
        Dim GroupList As List(Of ComponentGroup) = New List(Of ComponentGroup)
        Dim FromOrigin() As Double = Nothing
        Dim FromXAxis() As Double = Nothing
        Dim FromYAxis() As Double = Nothing
        Dim ArrangementTable As Tag = Nothing
        Dim Cellvalue As String = Nothing
        Dim numRows As Integer = Nothing
        Dim numCols As Integer = Nothing
        Dim rowTag As Tag = Nothing
        Dim colTag As Tag = Nothing
        Dim cellTag As Tag = Nothing
        Dim ArrangementName As String = Nothing
        Dim VariablesTitle As List(Of String) = New List(Of String)
        Dim DelArrangementList As List(Of Arrangement) = New List(Of Arrangement)
        Dim DefArrangementTag As Tag = Nothing
        ufs.Assem.AskDefaultArrangement(workPart.Tag, DefArrangementTag)
        Dim DefArrangement As Arrangement = Utilities.NXObjectManager.Get(DefArrangementTag)
        Dim Resp As MsgBoxResult = Nothing
        Resp = MsgBox("Default Arrangement is '" & DefArrangement.Name & _
               "' , Press Yes to continue the update or Press No to Exit", vbYesNo, "Default Arrangement")
        If Resp = MsgBoxResult.No Then
            Exit Sub
        ElseIf Resp = MsgBoxResult.Yes Then
            'Delete all the existiing Arrangement in workpart
            For Each DelArrangment As Arrangement In workPart.ComponentAssembly.Arrangements
                If Not DelArrangment.Name = DefArrangement.Name Then
                    DelArrangementList.Add(DelArrangment)
                End If
            Next
            For i = 0 To DelArrangementList.Count - 1
                DelArrangementList(i).Delete(True)
            Next
        End If
        Dim PartClean As PartCleanup
        PartClean = theSession.NewPartCleanup()
        PartClean.TurnOffHighlighting = True
        PartClean.DeleteUnusedObjects = True
        PartClean.DeleteUnusedExpressions = True
        PartClean.CleanupDraftingObjects = True
        PartClean.CleanupFeatureData = True
        PartClean.FixOffplaneSketchCurves = True
        PartClean.DeleteInvalidAttributes = True
        PartClean.CleanupMatingData = True
        PartClean.CleanupAssemblyConstraints = True
        PartClean.DeleteUnusedFonts = True
        PartClean.CleanupCAMObjects = True
        PartClean.DeleteBrokenInterpartLinks = True
        PartClean.CleanupRoutingData = True
        PartClean.DeleteVisualEditorData = True
        PartClean.DoCleanup()
        PartClean.Dispose()
        'ArrangementOptions.IndividuallyPositioned and Position override for each assemblies
        Try
            Dim Mycomponent As ComponentAssembly = workPart.ComponentAssembly
            UpdateArrangementPosition(Mycomponent.RootComponent, 0)
        Catch e As Exception
            lw.WriteLine("Assembly component Individually Postitioned Option failed : " & e.ToString)
        End Try
        Try
            Dim MyHideList As List(Of Component) = New List(Of Component)
            ComponentHide(Mycomponent.RootComponent, 0, MyHideList)
            Dim MyHideObj() As DisplayableObject = MyHideList.ToArray
            theSession.DisplayManager.BlankObjects(MyHideObj)
            workPart.ModelingViews.WorkView.FitAfterShowOrHide(NXOpen.View.ShowOrHideType.HideOnly)
        Catch ex As NXException
            lw.WriteLine("error 110")
        End Try
        'Collect all Component group detail and Template coordinate system details
        For Each Mygroup As ComponentGroup In workPart.ComponentGroups
            If TypeOf Mygroup Is ComponentGroup Then
                GroupList.Add(Mygroup)
            End If
        Next
        For Each MyCsys As CoordinateSystem In workPart.CoordinateSystems
            If TypeOf MyCsys Is CoordinateSystem Then
                If Not MyCsys.Name = "" Then
                    PrimeCsysList.Add(MyCsys)
                End If
            End If
        Next
        'Collect all the Details from Primary CSYS before applying the formula or Else for both Primary and secondary Csys will return the same value
        Dim FromOriginX As Double = Nothing
        Dim FromOriginY As Double = Nothing
        Dim FromOriginZ As Double = Nothing
        Dim FromOriginXx As Double = Nothing
        Dim FromOriginXy As Double = Nothing
        Dim FromOriginXz As Double = Nothing
        Dim FromOriginYx As Double = Nothing
        Dim FromOriginYy As Double = Nothing
        Dim FromOriginYz As Double = Nothing
        Dim Xcollection As List(Of Double) = New List(Of Double)
        Dim Ycollection As List(Of Double) = New List(Of Double)
        Dim Zcollection As List(Of Double) = New List(Of Double)
        Dim Xxcollection As List(Of Double) = New List(Of Double)
        Dim Xycollection As List(Of Double) = New List(Of Double)
        Dim Xzcollection As List(Of Double) = New List(Of Double)
        Dim Yxcollection As List(Of Double) = New List(Of Double)
        Dim Yycollection As List(Of Double) = New List(Of Double)
        Dim Yzcollection As List(Of Double) = New List(Of Double)
        For i = 0 To PrimeCsysList.Count - 1
            FromOriginX = PrimeCsysList(i).Origin.X
            FromOriginY = PrimeCsysList(i).Origin.Y
            FromOriginZ = PrimeCsysList(i).Origin.Z
            FromOriginXx = PrimeCsysList(i).Orientation.Element.Xx
            FromOriginXy = PrimeCsysList(i).Orientation.Element.Xy
            FromOriginXz = PrimeCsysList(i).Orientation.Element.Xz
            FromOriginYx = PrimeCsysList(i).Orientation.Element.Yx
            FromOriginYy = PrimeCsysList(i).Orientation.Element.Yy
            FromOriginYz = PrimeCsysList(i).Orientation.Element.Yz
            Xcollection.Add(FromOriginX)
            Ycollection.Add(FromOriginY)
            Zcollection.Add(FromOriginZ)
            Xxcollection.Add(FromOriginXx)
            Xycollection.Add(FromOriginXy)
            Xzcollection.Add(FromOriginXz)
            Yxcollection.Add(FromOriginYx)
            Yycollection.Add(FromOriginYy)
            Yzcollection.Add(FromOriginYz)
        Next
        ' Read expression value from table for each arrangement and update the sketch to move the coordinates and update arrangement
        Dim myTabularNoteTags As New List(Of Tag)
        If FindTabularNotes(myTabularNoteTags, workPart) = 0 Then
            'no tabular notes to process
            Return
        End If
        For Each tableNote As Tag In myTabularNoteTags
            ufs.Tabnot.AskNmRows(tableNote, numRows)
            ufs.Tabnot.AskNmColumns(tableNote, numCols)
            ufs.Tabnot.AskNthRow(tableNote, 0, rowTag)
            ufs.Tabnot.AskNthColumn(tableNote, 0, colTag)
            ufs.Tabnot.AskCellAtRowCol(rowTag, colTag, cellTag)
            ufs.Tabnot.AskCellText(cellTag, Cellvalue)
            If Cellvalue = "Arrangements list" Then
                ufs.Tabnot.AskNthRow(tableNote, 1, rowTag)
                For j = 1 To numCols - 1
                    ufs.Tabnot.AskNthColumn(tableNote, j, colTag)
                    VariablesTitle.Add(Cellvalue)
                Next
                For i = 2 To numRows - 1 Step 1
                    ufs.Tabnot.AskNthRow(tableNote, i, rowTag)
                    Dim Variables As List(Of String) = New List(Of String)
                    For j = 0 To numCols - 1
                        Variables.Add(Cellvalue)
                    Next
                    ArrangementName = Variables(0)
                    Dim MyArrangement As Assemblies.Arrangement = Nothing
                    MyArrangement = workPart.ComponentAssembly.Arrangements.Create(DefArrangement, ArrangementName)
                    lw.WriteLine("Creating " & ArrangementName.ToString)
                    MyArrangement.IgnoringConstraints = True
                    workPart.ComponentAssembly.RootComponent.SetUsedArrangement(MyArrangement)
                    workPart.ComponentAssembly.ActiveArrangement = MyArrangement
                    Variables.RemoveAt(0)
                    For iii As Integer = 0 To Variables.Count - 1
                        If Variables(iii).ToString = "NA" Then
                            Variables(iii) = "0"
                        End If
                    Next
                    If VariablesTitle.Count = Variables.Count Then
                        For k = 0 To VariablesTitle.Count - 1
                            Try
                                'This expression will move the base sketch and move the coordinate system to new location
                                Dim markId1 As Session.UndoMarkId
                                markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Expression")
                                Dim expression1 As Expression = CType(workPart.Expressions.FindObject(VariablesTitle(k)), Expression)
                                expression1.RightHandSide = Variables(k)
                                theSession.Preferences.Modeling.UpdateDelayed = True
                                theSession.Preferences.Modeling.UpdatePending = True
                                Dim nErrs1 As Integer
                                nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
                                lw.WriteLine(VariablesTitle(k) & ":  " & ex.Message)
                            End Try
                        Next
                                    SecondaryCsysList.Add(MyCsys)
                                End If
                            End If
                        Next
                        For ii = 0 To PrimeCsysList.Count - 1
                            Dim Movinggroup As ComponentGroup = Nothing
                            Dim fromCsys As CoordinateSystem = PrimeCsysList(ii)
                            FromOrigin = {Xcollection(ii), Ycollection(ii), Zcollection(ii)}
                            FromXAxis = {Xxcollection(ii), Xycollection(ii), Xzcollection(ii)}
                            FromYAxis = {Yxcollection(ii), Yycollection(ii), Yzcollection(ii)}
                            'Comparing
                            Dim toCsys As CoordinateSystem = Nothing
                            For ij = 0 To SecondaryCsysList.Count - 1
                                If SecondaryCsysList(ij).Name = fromCsys.Name Then
                                    toCsys = SecondaryCsysList(ij)
                                End If
                            Next
                            Dim toOrigin() As Double = {toCsys.Origin.X, toCsys.Origin.Y, toCsys.Origin.Z}
                            Dim toXAxis() As Double = {toCsys.Orientation.Element.Xx, toCsys.Orientation.Element.Xy, toCsys.Orientation.Element.Xz}
                            Dim toYAxis() As Double = {toCsys.Orientation.Element.Yx, toCsys.Orientation.Element.Yy, toCsys.Orientation.Element.Yz}
                            Dim mtx4Transform(15) As Double
                            ufs.Mtx4.CsysToCsys(FromOrigin, FromXAxis, FromYAxis, toOrigin, toXAxis, toYAxis, mtx4Transform)
                            'Extract the rotation matrix and the tranlsation vector
                            Dim rotMatrix(8) As Double
                            ufs.Mtx4.AskRotation(mtx4Transform, rotMatrix)
                            Dim transVec(2) As Double
                            ufs.Mtx4.AskTranslation(mtx4Transform, transVec)
                            'Convert array of doubles to vector 3d
                            Dim translateVector As Vector3d = New Vector3d(transVec(0), transVec(1), transVec(2))
                            'Convert array of doubles to Matrix3x3
                            Dim rotationMatrix As Matrix3x3 = convertToMatrix3x3(rotMatrix)
                            'Find which component group to move based on Primarycsys
                            Dim Groupobjects() As NXObject = Nothing
                            Try
                                For ik = 1 To GroupList.Count - 1
                                    If GroupList(ik).Name = fromCsys.Name Then
                                        Movinggroup = GroupList(ik)
                                        Groupobjects = Movinggroup.GetComponents
                                        'lw.WriteLine(Movinggroup.Name & ": Components Count: " & Groupobjects.Length.ToString)
                                    End If
                                Next
                            Catch ex As Exception
                                lw.WriteLine(ex.Message)
                                GoTo NextGroup
                            End Try
                            Try
                                'Move groups for each arrangement as per Primary to Secondary Csys move
                                Dim componentPositioner1 As Positioning.ComponentPositioner
                                componentPositioner1 = workPart.ComponentAssembly.Positioner
                                componentPositioner1.ClearNetwork()
                                componentPositioner1.BeginMoveComponent()
                                componentPositioner1.PrimaryArrangement() = MyArrangement
                                Dim allowInterpartPositioning1 As Boolean
                                allowInterpartPositioning1 = theSession.Preferences.Assemblies.InterpartPositioning
                                Dim network1 As Positioning.Network
                                network1 = componentPositioner1.EstablishNetwork()
                                Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork)
                                componentNetwork1.NonMovingGroupGrounded = True
                                componentNetwork1.MoveObjectsState = True
                                componentNetwork1.RemoveAllConstraints()
                                componentNetwork1.SetMovingGroup(Groupobjects)
                                Dim loaded1 As Boolean
                                loaded1 = componentNetwork1.IsReferencedGeometryLoaded()
                                componentNetwork1.BeginDrag()
                                componentNetwork1.DragByTransform(translateVector, rotationMatrix)
                                componentNetwork1.EndDrag()
                                componentNetwork1.ResetDisplay()
                                componentNetwork1.ApplyToModel()
                                componentNetwork1.Solve()
                                Dim nErrs2 As Integer
                                nErrs2 = theSession.UpdateManager.AddToDeleteList(componentNetwork1)
                                componentPositioner1.DeleteNonPersistentConstraints()
                                componentPositioner1.EndMoveComponent()
                                GoTo NextGroup
                            End Try
NextGroup:
                        Next
                    Else
                        lw.WriteLine("Table has missing Parameters or Parameter Title count and Value count not matching")
                    End If
                Next
            End If
        Next
        workPart.ComponentAssembly.RootComponent.SetUsedArrangement(DefArrangement)
        workPart.ComponentAssembly.ActiveArrangement = DefArrangement
        Dim NewArrangementsList As List(Of Arrangement) = New List(Of Arrangement)
        For Each NewArrangment As Arrangement In workPart.ComponentAssembly.Arrangements
            If Not NewArrangment.Name = DefArrangement.Name Then
                NewArrangementsList.Add(NewArrangment)
            End If
        Next
        Try
            Dim SuppressGroup As ComponentGroup = CType(workPart.ComponentGroups.FindObject("SUPPRESSED"), ComponentGroup)
            Dim ArrangementListForSuppress() As Arrangement = NewArrangementsList.ToArray
            Dim errorList1 As ErrorList
            errorList1 = workPart.ComponentAssembly.SuppressComponents(SuppressGroup.GetComponents, ArrangementListForSuppress)
            errorList1.Dispose()
            lw.WriteLine("Suppress: " & ex.Message)
        End Try
        Try
            theSession.DisplayManager.UnblankObjects(MyHideObj)
            workPart.ModelingViews.WorkView.FitAfterShowOrHide(NXOpen.View.ShowOrHideType.ShowOnly)
            lw.WriteLine("error 366")
        End Try
    End Sub
    Function convertToMatrix3x3(ByVal mtx As Double()) As Matrix3x3
        Dim mx As Matrix3x3
        With mx
            .Xx = mtx(0)
            .Xy = mtx(1)
            .Xz = mtx(2)
            .Yx = mtx(3)
            .Yy = mtx(4)
            .Yz = mtx(5)
            .Zx = mtx(6)
            .Zy = mtx(7)
            .Zz = mtx(8)
        End With
        Return mx
    End Function
    Function FindTabularNotes(ByRef theTabNotes As List(Of Tag), ByVal Mypart As Part) As Integer
        Dim tmpTabNote As NXOpen.Tag = NXOpen.Tag.Null
        Dim type As Integer
        Dim subtype As Integer
        Do
            ufs.Obj.CycleObjsInPart(Mypart.Tag, UFConstants.UF_tabular_note_type, tmpTabNote)
            If tmpTabNote = NXOpen.Tag.Null Then
                Continue Do
            End If
            If tmpTabNote <> NXOpen.Tag.Null Then
                ufs.Obj.AskTypeAndSubtype(tmpTabNote, type, subtype)
                If subtype = UFConstants.UF_tabular_note_subtype Then
                    theTabNotes.Add(tmpTabNote)
                End If
            End If
        Loop Until tmpTabNote = NXOpen.Tag.Null
        Return theTabNotes.Count
    End Function
    Sub UpdateArrangementPosition(ByVal comp As Component, ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
            If child.GetChildren.Length <> 0 Then
                ' lw.WriteLine(child.Name)
                Try
                    Dim nullAssemblies_Component As Assemblies.Component = Nothing
                    child.EstablishPositionOverride(nullAssemblies_Component)
                    Dim MyObj(0) As NXObject
                    MyObj(0) = child
                    Dim assembliesParameterPropertiesBuilder1 As AssembliesParameterPropertiesBuilder = workPart.PropertiesManager.CreateAssembliesParameterPropertiesBuilder(MyObj)
                    assembliesParameterPropertiesBuilder1.Arrangements = Assemblies.AssembliesParameterPropertiesBuilder.ArrangementOptions.IndividuallyPositioned
                    Dim NxObject1 As NXObject
                    NxObject1 = assembliesParameterPropertiesBuilder1.Commit()
                    assembliesParameterPropertiesBuilder1.Destroy()
                    lw.WriteLine("Failed To Position Override")
                End Try
            Else
                Try
                    If Not child.GetPositionOverrideType.ToString() = "Explicit" Then
                    End If
                    MyObj(0) = child
                End Try
            End If
            UpdateArrangementPosition(child, indent + 1)
        Next
    End Sub
    Sub ComponentHide(ByVal comp As Component, ByVal indent As Integer, ByRef Hidelist As List(Of Component))
                Try
                    Hidelist.Add(child)
                End Try
            Else
                Try
                    Hidelist.Add(child)
                End Try
            End If
            ComponentHide(child, indent + 1, Hidelist)
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
