Assigning a unit
Hello everyone!
I know one method to assign a unit variable: Unit kg = (Unit)workPart.UnitCollection.FindObject("Kilogram");
Is this the only way to make it? Or is it possible to assign it in a more traditional way?
Re: Assigning a unit
Basically, what I am unhappy about is that units defined in this way are the units of the particular part. If I need to assign attributes with this units to another part, I need to take extra steps to convert units so that they are the same type but from another part. I have a nagging feeling that I am doing something wrong. Man Happy
What you could use is:
BasePart.Units unit = theSession.Parts.Work.PartUnits;
This returns the base units. Trying to understand if that's what you are looking for.
But it is also returns units of a work part, no?
