Block Reaching the Costumer Defaults
Hello ,
I'm using NX with TC integration . I don't know my question is related with NX or TC. As you know all users can change the NX settings from File < Utilities < Customer Defaults . However , sometimes it will be occured missunderstood problems in the company. I want to blocking to reach Customer Defaults settings for user side. If it is possible how can i manage that problem ?
Best Regards
Gurkan
Re: Block Reaching the Costumer Defaults
You might be able using Menuscript.
But then *you* may not be able to access them either!
Another option (assuming you have a SITE or GROUP level customer defaults) is to lock the required settings at the site/group level.
Then (at the OS level) make sure only the proper people have write access to the SITE/GROUP settings folder
