Block Styler SelectPartFrom List Question
I have created a BlockStyler application that uses the SelectPartFromList block and I am not sure
how to display the name(s) of the component(s) that have been selected in a messagebox. I am using this block to select components in an assembly.
Scott
NX9.0
VB.Net
Re: Block Styler SelectPartFrom List Question
This worked for me:
(In the update callback)
            If block Is selectPart0 Then
                Dim theParts() As TaggedObject = _
                    selectPart0.GetProperties.GetTaggedObjectVector("SelectedObjects")
                Dim longString As String = ""
                For Each thisPart As Part In theParts
                    longString = longString & "   " & thisPart.Leaf
                Next
                MsgBox(longString, MsgBoxStyle.Information)
            End If
Thanks Steve, this did the trick!
Scott
