Block Styler
Hello everybody!
I create dialog with Block Styler. I added checkbox in my dialog. I need do next: if checkbox is on there appears another one window with another block of dialog. How I can do this?
Re: Block Styler
Use the update callback. Set the Show property of the block you want to toggle on/off equal to the Value of the toggle block.
Re: Block Styler
Thanks!
