Block UI Styler - Clear Selected Bodies
I am trying to clear the Body Collector block by using an Action Button in the Block UI Styler interface but can't get it to work. Based on another post I read, I tried the code below but get a Null Reference Exception when it's exectuted.
Dim emptyVector() As TaggedObject = Nothing
selObject.SetSelectedObjects(emptyVector)
Any thoughts?
Re: Block UI Styler - Clear Selected Bodies
You can't set the emptyVector to Nothing. You MUST have emptyVector set to a zero length array.
I don't use VB so I can't recall how to do that, but in Java it would be something like:
TaggedObject[] emptyVector = {};
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
Replacing Nothing with {} did the trick.
Thanks for your help.
Cheers
