Block UI Styler Node Tree - How to edit node display text by Doule Click?
NX 10.0.3 NXOpen C++ Windows 64x
I created a NodeTree block in my UI.  I found that users can only triple click the node rather than double click to make the text in edit. For example users have to triple click the 176.37 to make it editable. How can I solve the problem?
I use SetOnBeginLabelEditHandler and SetOnEndLabelEditHandler to edit the node display text in a specified column.
Re: Block UI Styler Node Tree - How to edit node display text by Doule Click?
Hi Xiang,
I too had this problem while editing the node in the column. I solved the problem by simulating a left mouse click action once when the user double click on the column. We can the add simulating/auto-click of left mouse click program in the SetOnDefaultActionHandler callback. This callback is triggered once the user double clicked on the node. It worked for me.
Thanks and Regards,
Deepak
Hello Deepak,
Thank you so much. I pasted the code below. It seems can only be applied to Windows, is there any way to do this at LINUX system?
Regards, Xiang
#ifdef _WIN32
    #include <Windows.h>
#endif
void Modeling:Smiley SurprisednDefaultAction(NXOpen::BlockStyler::Tree *tree, NXOpen::BlockStyler::Node *node, int columnID)
#ifdef _WIN32
    INPUT Input = { 0 };
    Input.type = INPUT_MOUSE;
    Input.mi.dwFlags = MOUSEEVENTF_LEFTDOWN;
    :Smiley FrustratedendInput(1, &Input, sizeof(INPUT));
    ::ZeroMemory(&Input, sizeof(INPUT));
    Input.mi.dwFlags = MOUSEEVENTF_LEFTUP;
#endif
