Re: Block UI Styler : The problem of SelectionManager.SelectTaggedObject
Hi Stefan_Pendl,
i reference jimB reply and your code,
i know how to use Selection.MaskTriple,
but the final row of your code:
selectAffectedObject.SetSelectionFilter(Selection.SelectionAction.EnableSpecific,oSelectionMask)
is it same use the NXOpen.BlockStyler.SelectObject.SetSelectionFilter(),
if so, i suppose that your code maybe is
NXOpen.BlockStyler.SelectObject  selectAffectedObject = new NXOpen.BlockStyler.SelectObject()
selectAffectedObject.SetSelectionFilter (Selection.SelectionAction.EnableSpecific,oSelectionMask)
but i try new the  NXOpen.BlockStyler.SelectObject(),but it can't be build.
Could you tell me how to type this code?
Thx
Betreff: Block UI Styler : The problem of SelectionManager.SelectTaggedObject
No problem.
In your case, the selection mask is probably the most straight forward approach.
I often use the filter_cb approach because one can easily realize more specific filtering (e.g. all planar faces that are smaller than xyz).
With the filter_cb this should work for you.
    public int filter_cb(NXOpen.BlockStyler.UIBlock block, NXOpen.TaggedObject selectedObject)
        int res = NXOpen.UF.UFConstants.UF_UI_SEL_ACCEPT;
        if(block == yourSelectionBlock)
           if( !(selectedObject is NXOpen.Face)  || (NXOpen.Face)selectedObject.SolidFaceType != Face.FaceType.Planar) res = NXOpen.UF.UFConstants.UF_UI_SEL_REJECT;
        return res;
Jan
Jan Böttcher
Hi jan,
So, both of  MaskTripple and filter_cb can achieve the goal in my case,right?
It seems that filter_cb is really better and i can directly understand it.
And i try your code, occured the problem below:
my selectedObject doesn't have the option of SolidFaceType .
Am i loss something?
i change the code below,
if (!(selectedObject is NXOpen.Face) || (NXOpen.Face.FaceType)selectedObject.Tag!= Face.FaceType.Planar) res = NXOpen.UF.UFConstants.UF_UI_SEL_REJECT;
it didn't have error message in C#,but can't choose anything in NX10.
Hi wkl,
I made a mistake in my code. I forgot the second pair of brackets around the cast (copy and past with not enough coffee). TaggedObject naturally has no property SolidFaceType but Face has.
           if( !(selectedObject is NXOpen.Face)  || ((NXOpen.Face)selectedObject).SolidFaceType != Face.FaceType.Planar) res = NXOpen.UF.UFConstants.UF_UI_SEL_REJECT;
        return res;
It's Ok to use the approach you better understand. I don't think that there are any significant drawbacks using this even in simple cases.
Jan
Jan Böttcher
I am using a selection block.
    Private selectAffectedObject As NXOpen.BlockStyler.SelectObject' Block type: Selection
            selectAffectedObject = CType(theDialog.TopBlock.FindBlock("selectAffectedObject"), NXOpen.BlockStyler.SelectObject)
The block must be part of the dialog DLX file.
Hi Jan,
Until now, i just know that the code can use like below,
Before your help, i think that (NXOpen.Face)selectedObject has already let TaggedObject  transformed into Face.
You help me a lot, not only solve the problem i have,but also  learn a valuable lesson.
Thanks a lot !
wkl
