Block UI Styler
Is it possible to use something similar to a datepicker in Block UI Styler? It's not available in Block UI for NX10.
I'm adding string attributes with the date that will be used by a note on the drawing.
Re: Block UI Styler
I don't think anything like that is available in BlockStyler.
You might be able to cobble your own together using enumerations or something...
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
