Block styler -> focus on apply.
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I have a block styler dialog containing a face collector and a select object widget.
The dialog has OK/APPLY/CANCEL.
both selection widgets are stepstatus required.
When the selections are satisfied, I would like the apply(not ok) to get the focus.
Is it possible to transfer focus to the Apply widget? We have a case where this dialog is ideally repeatedly invoked and hence will not apply until all cases are exhausted.
Re: Block styler -> focus on apply.
There are dialogs in NX behaving like that.
Unfortunately, this ability has not been exposed to NX Open, at least not yet.
